Front Suspension 96 3500 4x4
Over the past few months I replaced front brakes, rotors, calipers, u-joints, seals, tie rods, ends, you get the pic. The only things I did not replace were the track bar, pitman arm and ball joints. It seemed they were OK. Well seemed bit me in the ***. I definitely am now replacing the track bar, bad drivers side swivel joint. The pitman arm, just because. And I am putting on one of the aftermarket CNC machined steering box stabilizer, nice unit. BUT I just noticed what may be a ball joint problem, 250K miles, one owner. I am no mechanic but have alot of experience in working on my Dodge for 20 years. After taking off both front wheels/tires I grabbed the lug studs on D-side and pulled up and down, there is just a small amount of play on the bottom ball joint, but I don't think this is OK, IS IT??? If not should I replace both upper and lower and of course on both sides if so.
Thanks Guys
Let me know JB and Coke time
Mike
Thanks Guys
Mike
case310350
May 10, 2011 06:31 PM
Subliminal
Dec 13, 2010 05:58 PM
Pa outlaw
Jan 13, 2006 09:54 AM
army_guy
Aug 27, 2004 03:07 AM
