Front end vibration???????
Old Dec 19, 2011 | 02:52 PM
CTDkid's Avatar
Hey guys,
I have a vibration that comes and goes in the front end. Usually I would point to the wheel bearing as the culprit but just doesn't seem like the issue. The problem is very intermitent. Doesn't even happen everytime I drive the truck. The truck will be fine until I hit a good bump and then I will get a vibration that I can feel in the steering wheel and under my feet. It is definitly rotational. The really strange thing is when I engage the 4 wheel drive the vibration goes away. I am going to change the front diff fluid and see if that makes a difference.
Is it possible the axle bearing is going bad?
Thank you
Old Dec 19, 2011 | 05:38 PM
tech-eh's Avatar
no probably not type in death wobble in the search engen here and check your center-link . You should also check your steering box/frame mounts for crackes
Old Dec 19, 2011 | 05:47 PM
9812vram's Avatar
Do you have manual locking hubs? Almost sounds like it could be your front drive shaft too. In 4x with a little pressure on it maybe it smooths it out...
Old Dec 19, 2011 | 08:32 PM
CTDkid's Avatar
Its not death wobble thats for sure. Its not a shake its just a rotational vibration. Its almost like the sound and feeling of having really knobby tires. Hard to explain, but nothing I have felt before.
No I don't have manual hubs... Would be nice though haha. I will disconnect the front driveshaft and see if it still happens tomorrow.
Thank you for the input keep it coming please...
Gordonville
Apr 18, 2005 09:45 AM
oregon ram
Jul 21, 2004 06:11 PM
BigBlue
May 11, 2004 04:59 PM
Commatoze
Nov 21, 2003 07:55 PM
bcb1962
Jun 24, 2003 10:16 PM
