Frequency Valve Adj?
Not sure what the manuel calls for but with almost 300,000 miles on the clock i have only adjusted 3 times and one of those times was due to the fact that I changed my injectors and turbo and timing (15.5%).
I adjusted mine the first time at 25k miles, they needed very little.
Since then it's been every 100k and nothing was needed, it was a waste of time.
If you don't know the truck's adjustment history adjust them, otherwise wait a long time.
I did not know these engines had solid lifters, this has me worried- what on earth makes so much noise duirng the first 5 seconds after startup if its not the lifters? my 12V is very noisy until the oil pressure hits 40psi then instant quiet.
Fanged03
24
Sep 28, 2011 07:26 AM
2FEATHERS
Mar 4, 2009 08:43 PM
