first oil change in truck
Hey all. I about to buy all the fluids to change all the lubricants in the truck. a few Questions;
1) Are these capacities correct off the Amsoil website?
and do I add a quart to engine to account for filter?
CAPACITIES
Engine, without filter..........10.0 quarts
Manual Transmission, NV4500..........8.0 pints
Differential, 4WD with Dana 80 Rear..........10.0 pints
Differential, with Dana 60 Front..........7.6 pints[5]
Transfer Case,NP231, 233..........2.5 pints
Transfer Case,NV241HD W/ PTO..........10.0 pints
Transfer Case,NP241HD..........6.5 pints
Transfer Case,NP241..........5.7 pints
2) which transfercase do I have in my 1996 2500, with 5sp and 12v? is there a good way to identify it?
3) with limited slip differentials...I was told there is an additive to add with the gear-lube. any recommendations? is that the Mopar Trac-loc additive.
Thanks for the help...that should be all the questions...for now!
JT
CAPACITIES
JT
I run the AMSOIL throughout mine and I put a full 3 gallon in the engine with a filter change. The other capacities I found were a little on the fat side. My drivetrain did not hold as much as the website dictated, so you will have a little extra. Better that than not enough!!
jmccart
13
May 27, 2009 09:45 PM
1stTimeAround
Oct 10, 2004 04:02 PM
doitl8r
Jun 4, 2004 11:14 AM
snice
14
Apr 29, 2003 08:41 PM
pwabbott
Nov 15, 2002 03:28 PM
