finding center when replacing a steering box?
Old Aug 10, 2008 | 07:25 PM
Rattlerattle's Avatar
So finally had enough of the truck shaking down the road. The steering box had a fair bit of play so decided to replace it along with upgrading to the t-steering setup.
I am not sure if the box is centered. What is the best way to figure this out? Turn the wheel all the way to one lock, count the revolutions to the opposite lock and divide by two? I want to make sure the steering wheel and box are centered before putting on the new drag link.
TIA
Brian
Old Aug 11, 2008 | 09:56 AM
infidel's Avatar
Your counting the revolutions method is exactly what I would use.
Old Aug 11, 2008 | 02:35 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
TIA
Brian[/QUOTE]
Thats what I did...it worked...
Old Aug 11, 2008 | 05:59 PM
Thanks for the replys. I will have to center the steering wheel as well as the steering box since it seems that the reman box I got didn't come centered.
And hopefully it will drive better after!
Old Aug 11, 2008 | 09:14 PM
JohnX's Avatar
When you take it apart....Be very careful. Center the steering wheel and lock it in place(tie off with a rope or something). DO NOT turn the wheel without the steering gear connected to it.
You may disregard everything I said if your truck hasn't got an Airbag.
Old Aug 11, 2008 | 09:44 PM
I did tie off the steering wheel it is just a couple of degree's off from when I originally put the lift in.
It 'kind' of has an airbag, I hate those stupid things so put a blown fuse in the airbag fuse spot and took out the airbag idiot light that comes on when there is no fuse in place.
Old Aug 12, 2008 | 09:18 AM
JohnX's Avatar
Airbag vehicles use a clock spring in the column. What many people don't realize is that it is entirely possible to install a gear box a full revolution off. This is usually done by turning the wheel accidentally with the gear box out. Then they install the new box and drive away. Problem is the first time they make a sharp turn that direction, clockspring over rotates....and poof, air bag in your face
Shouldn't matter if you have it unhooked, but do it right anyway just incase you sell the truck and the person reconnects it.
Old Aug 12, 2008 | 04:53 PM
GAmes's Avatar
The clockspring is also for the horn and the cruise control, so not rotating the wheel is good advice for everyone.
Old Aug 12, 2008 | 06:29 PM
Sounds good, lets see if I total understand then.
Am I correct to assume that there is no stop per say in the steering column, that with it unhooked from the steering box you could turn the wheel round and round until you break the clockspring? It is there steering box that has the stop that will prevent the wheel turning?
Make sense. I haven't moved the wheel as it was tied down. So if I center the box then slightly move the steering wheel to align it with the centered box and hooked the steering shaft back to the box before reinstalling the drag link.
Thanks again.
Old Aug 13, 2008 | 09:34 AM
Coagulation's Avatar
Muted User
When I had my truck I removed the stock steering wheel with its airbag and replaced it with a sweet after market one, it was SOOOOOO much better and ditching the airbag was in my mind a good mod, plus there fun to set off lmao.
Oh and I moved the cruise switches to the dash, used some sweet metal toggles for that and I rigged the horn to the aftermarket wheel I got.
If its a 2nd gen it HAS a clockspring
ssleeper94
Dec 30, 2009 12:58 AM
ssleeper94
Dec 29, 2009 08:49 AM
ldornak
14
Jun 21, 2009 03:04 PM
unioncreek
Jun 29, 2005 02:00 PM
