Finally found my tranny fluid leak
I'd been crawling under my 96 4x4 looking for the leak for weeks and never could find it. I disconnected the clamps that hold the two lines together, cleaned everything off and still no leaks. Then I re-clamped the lines together and lo and behold, the fluid started POURING out where the line goes into the heat exchanger on the side of the engine. I DON'T WANT A NEW FACTORY LINE, WHAT FITTINGS DO I NEED TO USE TO REPLACE THAT LINE WITH TRANSMISSION FLUID HOSE?
leaks
blackram2500
Apr 29, 2010 04:36 PM
