Explain the KDP jig please
Old Jun 24, 2007 | 03:20 PM
kas83's Avatar
When I bought my 97, the PO had said the KDP was 'killed' by using the jig. It's always had a leak, but got way worse this weekend. After looking around, I believe I have found a decent sized piece on the timing cover pushed out. I will have to get in there and clean it up good to know for sure, but I fear that the pin fell out. If that is the case, the new stepped cover will be going on to cure the problem.
Old Jun 24, 2007 | 03:41 PM
AggieJustin's Avatar
From what I understand, the KDP jig is basically what it sounds like. The jig bolts to the engine and guides you to drill a hole in the timing cover right at the point where the KDP sits. You thread a bolt into the hole to keep the pin from sliding out. If it was fixed using the jig method, you should be able to see the bolt threaded into the hole in the side of the case.
But then I could be wrong, since I am over-valved.
Old Jun 24, 2007 | 03:43 PM
displacedtexan's Avatar
Justin is right...
Odd for an Aggie
Old Jun 24, 2007 | 03:49 PM
We all get lucky at times...
I'd put a disclaimer in my sig, but I'm out of characters.
Old Jun 24, 2007 | 06:25 PM
infidel's Avatar
You can only see the jig bolt if the fan pulley mount is removed.
It's a tapered head bolt that sits flush with the timing cover when screwed down.
Old Jun 24, 2007 | 09:28 PM
Dshiftff's Avatar
this should help.
Old Jun 24, 2007 | 09:59 PM
CR785's Avatar
If that is the case, the new stepped cover will be going on to cure the problem.[/QUOTE]
What is the stepped cover? Any place to check it out?
Old Jun 25, 2007 | 02:31 AM
kas83's Avatar
I've seen the 'stepped' cover on a couple different sites. Instead of being straight through, the hole for the dowel pin has a step to it, the diameter decreases, so it doesn't allow the pin through.
Thanks for the pics, I will search everything out tomorrow. And after looking closer this evening with a good flashlight, I may have jumped to conclusions about the timing cover being pushed out. Will see in the morning.
Old Jun 25, 2007 | 08:44 AM
notomas's Avatar
what is the purpose of the dowel that falls out
Old Jun 25, 2007 | 09:04 AM
scottsjeeprolet's Avatar
the dowel locates the case that houses the gears and IP. They have been known to come out and sometimes destroy an engine.
Old Jun 25, 2007 | 06:47 PM
Dshiftff's Avatar
dont mistake a casting mark that is commonly in that area.
Old Jun 29, 2007 | 07:48 PM
kas83's Avatar
That's exactly what another guy had told me, and to make **** sure I hadn't done so. I didn't get a chance to check it out, and am now on the road til mid July. I'm hoping/praying it was a mistake on my part. Buddy of mine is going to steam it off, and it's going to a local diesel mechanic to get some top end maintnance done while they check it out. I wish I had more time at home to take care of everything, I hate having to get the simple stuff done by shops like this. We will see early next week.
bkay
Mar 12, 2003 06:44 PM
doodah
Dec 17, 2002 03:31 PM
richard
Dec 16, 2002 02:13 PM
Trickytrae
Nov 24, 2002 03:25 PM
