engine temp trouble
Old Jun 20, 2013 | 08:46 PM
98Slushbox's Avatar
engine temp trouble
I bought a truck recently, it had a bad tranny so i towed it home fixed the tranny and the first trip out it overheated. I pulled the t-stat and put in a new one and same thing. Ive tried 2 other t-stats since then and same problem. None of them have opened up. I ran it without one and of course it doesnt warm up to normal operating temp like it should but it doesnt overheat anymore and circulates just fine then. I even pulled the water pump just to inspect it and its just fine. All the t-stats ive used are parts store ones but i cant imagine having 3 bad t-stats. Anyone have any wierd trouble like this?
Old Jun 21, 2013 | 08:19 AM
patdaly's Avatar
What type of overheat, a slow temperature rise towards the red, or the "Oh my god, the needle looks like a rocket heading to the sun" overheat?
If slow, I would pull the Radiator and make really sure the fins are clean. If fast, I would first make sure you had the stat in right, then I would get either a genuine Cummins or Stant PREMIUM from a Napa or other full line ( not discount ) parts store.
Old Jun 21, 2013 | 10:38 AM
infidel's Avatar
I've had real bad luck with auto parts generic stats, think they're made to be used with gassers. Even if they work they don't last long.
Only use Cummins p/n 3925466, never a problem.
Old Jun 21, 2013 | 12:02 PM
BigIron70's Avatar
Cummins Guru
I agree with patdaly and check out your radiator for restriction first. Feel across radiator does it have any cold spots? outside of radiator clean front and back? Clutch fan doesn't free wheel when spun?
ridlangus123
Dec 30, 2013 08:36 PM
MossyOakCTD
19
Dec 28, 2010 09:11 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
firesine
Nov 24, 2005 10:58 AM
apache
Feb 22, 2004 05:27 PM
