Engine shaking/ miss
Old May 5, 2011 | 04:34 PM
w250_93's Avatar
Ill start out by telling you guys everything i've done up to this point. I've popped all the injectors an number 2 seem to act alittle different when i popped it. so i swapped #1 injector an #2 injector an nothing changed, it stayed on #2 I also swapped the dv's around an nothing changed. Then i done a compression test an all cylinders were 370-380 so that rules out the motor. Ive also checked the valve lash an it was all fine.
Could it be a air leak or something cause the fuel at the injection pump is milky looking (i have a air dog) or should i just go ahead an buy a new injection pump?
Diesel Jeff
Apr 19, 2014 07:39 AM
benito
May 19, 2009 08:47 AM
Sea Bass
Nov 28, 2003 03:22 PM
schmittmontana
Jul 20, 2003 06:38 PM
Striper
14
Jul 15, 2003 01:39 PM
