easy timing question
Originally Posted by Ramdriver15
how hard is it to adust timing... i got the barring tool on order from snap-on, and what else do i need to do it myself. I do have a dial indicator....
a drain from a cummins engine? or any type of drain plug? Where can i get the delivery valve socket? and also how hard would you say it will be for a fist timer getting in that deep?
Yes, Cummins drain plug. Though a bit expensive (at least from Dodge), I replaced my original since the square hole was getting rounded a bit.
Look at kd460's pic:
https://www.dieseltruckresource.com/...cat=500&page=1
As for the difficulty, ever change the timing chain and gears on an older American V-8? I think if you're up to an advanced "shade tree" level, you'll be good. Review the steps and judge for yourself:
http://dodgeram.info/tsb/1994/18-10-94a.htm
Better yet, make a connection with another member in your area that has done it before.
I ordered my delivery valve socket from Piers (ET9166, $30.00):
http://www.piersdiesel.com/DodgeUSPrice.htm
Originally Posted by JKM
it is much cheaper to use a 22mm bolt , 1.5mm thread pitch.
If you do need to buy one, try checking with a Cummins parts dealer for the plug and new sealing ring/gasket. I bet they'll be cheaper than the Dodge boys were. There is no Cummins dealer in the small city in which I live, so I bit the bullet and went to the local "*******". I have since found a small diesel shop that has connections with a large regional Cummins dealer in Oklahoma City (~100 miles away). They can have parts here for me overnight at no additional charge!
