Drain plug leak
Old Apr 1, 2007 | 08:19 PM
kevellis32's Avatar
Drain plug leak
I just changed the oil in my truck today and noticed a little leak coming from the drain plug. I did notice that the washer that was around the plug was abit misshaped but I didn't think about replacing it because I had no way of getting anywhere to get one. I read threads about people getting nylon washers to put around the plug. Can i get those at autozone or is there somewhere else i need to go? or are there any other good fixes for this?
Old Apr 1, 2007 | 08:20 PM
Dr. Evil's Avatar
get a nylon, or better yet, a copper one.
Old Apr 1, 2007 | 08:24 PM
TIMMY22's Avatar
I had that problem with my old oilpan (since changed to a new pan). I used to put 1 rap of teflon tape around it low on the threads of the plug. Problem solved.
Old Apr 1, 2007 | 08:29 PM
kevellis32's Avatar
do you get those nylon or copper washers at home depot or where? and with the teflon tape how low down on the plug are you talkin?
Old Apr 1, 2007 | 08:54 PM
TIMMY22's Avatar
very low, I'd say no more than 3/8" up from the washer. This way there is little or no chance of any teflon getting in your oil. I'd say 1 1/4 rap, make sure youre going the right direction so it doesnt unravel as you tighten.
works everytime without drip. used this on old tractors, mack trucks, you name it.
Old Apr 1, 2007 | 09:55 PM
Dr. Evil's Avatar
Any auto parts store should have the copper washers.
Old Apr 1, 2007 | 10:21 PM
latitude500's Avatar
I'm not sure if I would be brave enough to use tape, but I've used copper washers in the past and they work fine.
Old Apr 2, 2007 | 07:32 PM
kevellis32's Avatar
I just bought the washer from my local dodge dealer...for 7.25, what a frikkin rip off, and it still leaks, i guess I am going to try the teflon tape, and a copper washer now...any other advice?
Old Apr 2, 2007 | 08:07 PM
TIMMY22's Avatar
Just use the teflon. simple and cheap.
are you using infidel's idea with the shop-vac so you don't waste oil?
Old Apr 2, 2007 | 08:18 PM
kevellis32's Avatar
Naw, i don't have a shop vac or else I would and I don't wanna ask a neighbor and then have him see what I am doin and never let me borrow anything again. I just went and got a 15 gallon bucket, cleaned it really good and reuse the oil. that works just fine and only costs about 1.50. And with the tape, I want to wrap it in the opposite direction so it doesn't come off when I tighten it?
Old Apr 2, 2007 | 08:27 PM
TIMMY22's Avatar
Carefull no sand or grit falls into the bucket while youre under there. yes, wrap it so the tape does'nt unravel.
hold the plug bottom toward you. start tape on top with rest of roll to your left. rotate plug as if you were tightening it. cut tape after 1 1/4 turn. Install.
Old Apr 2, 2007 | 11:34 PM
Muddin_dude06's Avatar
I got a HD drain plug from Geno's, would have worked great but my pan is warped SOO what I do is just put a little bit of gasket-maker kind of stuff on it and I haven't had any problems when doing that.
Old Apr 2, 2007 | 11:38 PM
kevellis32's Avatar
what is gasket maker kind of stuff? and where do you get it?
Old Apr 3, 2007 | 12:06 AM
I have used "Permatex Blue" the last few times, it is just a liquid silicone sealent. You can get it at any auto parts store, works prettyy dang good for me
Old Apr 3, 2007 | 09:39 PM
kevellis32's Avatar
I went with all three suggestions, I got a new washer, put some teflon tape on exactly how you said, and put on the permatex ultra blue...and IT WORKED...thank you guys alot
