down pipe burried in firewall
Old Oct 15, 2010 | 11:17 PM
Silver Ram's Avatar
I put a different tubo on my truck and the down pipe is in a different location. It actually is burried in the firewall. What temp is that firewall blanket rated at? Is this in danger of catching fire?
Also my truck is now popping when I nail the go pedal. I had to remove and plug the small tube that goes to the AFC because this turbo has no waste gate. Would this be causing it to pop?
Old Oct 15, 2010 | 11:46 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Sounds like you need to clock that turbo a bit to get that thing off the firewall
Old Oct 17, 2010 | 10:07 AM
infidel's Avatar
I'd be more worried about noise than fire.
Anywhere the exhaust system touches the body makes an unbearable noise.
Old Oct 17, 2010 | 11:09 AM
Tate's Avatar
How would you clock the exhaust housing without flipping the manifold?
Old Oct 17, 2010 | 11:29 AM
Silver Ram's Avatar
I clocked the turbine housing and that helped some. I found a fuel leak. Not sure which one, if its supply or return it went behind the IP. I couldn't really see what it was connected to. I fixed it and put a new filter on it helped with the popping. I just get one pop now when I nail it instead of a bunch of pops. I can live with it for now. I'm definately going to need to redo the down pipe. Flex hose is ok in a pinch but I can see that it was not a permanent fix.
Old Oct 17, 2010 | 01:11 PM
torquefan's Avatar
There was a small recall in 97 or 98 regarding downpipes being too close to the sound deadener and causing them to burn. I've never seen one cause a fire, but this tells me that it could be a concern.
19Fury69
Apr 25, 2008 12:05 PM
Jordan5687
Feb 14, 2007 05:00 PM
Deezle1
Jan 16, 2005 11:29 PM
Stomp
Sep 14, 2004 11:49 PM
Planetcat
Jun 28, 2004 03:20 PM
