Differences between RH and RE
Old Jul 21, 2005 | 02:33 AM
Jambbii's Avatar
What are the differences in these transmissions? I heard that the RH has better inptut shafts.
Thanks
Old Jul 22, 2005 | 08:54 PM
bmoeller's Avatar
I've heard same about the shafts.
Auto Trans code breaks down like this:
4 = 4 forward speeds
7 = strength of trans. (1-9, higher number, stronger trans.)
R = Rear wheel drive
H=Hydraulic controlled, E = Electronic controlled shift
The input torque rating is the same, according to-
http://dodgeram.org/tech/transmission/4xre.htm
Do see one error, though. The RH was used '94 & '95. RE started in '96.
Old Jul 22, 2005 | 08:58 PM
MnTom's Avatar
My understanding after talking with Dave Goerends is that they are basicaly the same transmissions. About the only difference was the controls.
Old Jul 22, 2005 | 09:52 PM
marksmith's Avatar
The input and intermediate shafts are the same for the two trannies...
Its the output shaft that is different. Due to the model years you can not find a billet unit for the output. (YET!!! A limited run is going to be made)
The output on the RH is stouter than the RE for some reason.......
Other than the O/D controls.. they are the same.
Mark
CTD_Neil
Jan 12, 2005 06:07 PM
westport
Sep 23, 2003 07:15 AM
2001CamaroSS
Sep 12, 2003 07:45 PM
Dan C.
Aug 12, 2003 07:45 AM
