destroyed 12 valve pics
Old 12-06-2006, 05:18 PM
97ramctd's Avatar
Angry destroyed 12 valve pics
The ole girl just doesn't like to be run hard i guess. Driving down the road this past Saturday it starts to cut out and pop at higher rpm's. Figured it would be alright till i got home... WELL it wasn't a good idea to drive it home! Took no.1 valve cover off and noticed the exhaust valve wasn't rocking. Next day i tore it down only to find i bent the push rod in an S shape, broke a valve off, destroyed a piston, chipped the deck of the block, and smashed an injector tip flat. WooHoo how fun! New motor time!
Attached Thumbnails destroyed 12 valve pics-no.1-piston.jpg   destroyed 12 valve pics-no.-1-piston.jpg   destroyed 12 valve pics-no.-1-valves.jpg   destroyed 12 valve pics-valve-marks-head.jpg   destroyed 12 valve pics-valves-been-hitting.jpg
Old 12-06-2006, 05:21 PM
97ramctd's Avatar
oh yea and.....
I decided to tear it down farther today and also found out that the cam gear had broke also. Talk about maximum destruction!
Attached Thumbnails destroyed 12 valve pics-cam-gear.jpg   destroyed 12 valve pics-cam-gear2.jpg   destroyed 12 valve pics-cam-gear-off.jpg
Old 12-06-2006, 05:26 PM
FirstDodge's Avatar
Man . . . that's too bad. How many miles on it?
Old 12-06-2006, 05:29 PM
97ramctd's Avatar
not enough lol just rolled over 173,000
Old 12-06-2006, 05:32 PM
kawi600's Avatar
Ive seen pics of that very same failure someplace before. Wonder how common a failure that is.
Wonder if the gear caused the failure, or you had valve float and piston contact first. The bottom of a valve will certainly provide enough leverage to snap that cam gear. everything from springs to pushrods would be suspect.
Wonder how much a reman 12v motor is from a reputable outfit like jasper or something...
Old 12-06-2006, 05:34 PM
97ramctd's Avatar
I was told that i could get a reman long block for $4500 ..... Ouch!
Old 12-06-2006, 05:38 PM
kawi600's Avatar
Thats not too bad considering a transmission build-up is about that cost. Hope youre good with a cherry picker and can at least lower the labor cost
A new motor might be a good reason for a cam upgrade
Old 12-06-2006, 05:41 PM
97ramctd's Avatar
Yea i'm gonna do it all myself labor cost to much. I'm dreading buying a used motor much less a new one plus upgrades lol.
Old 12-06-2006, 05:58 PM
G1625S's Avatar
Yikes! Sorry for your troubles Wait'll these pics get over to The Diesel Stop et all....there'll be ''see what you get with the 'reliable' old 12v'' threads left and right
Old 12-06-2006, 06:39 PM
infidel's Avatar
My bet is the cam gear was the initial cause.
I know your sig says you killed the KDP but the cam gear breaking off like that is one of the things a dowel pin bouncing around in the case can do. If the dowel pin goes between the cam and crank gears, or cam and injection pump gears, it breaks the gear off the camshaft. The camshaft stops rotating causing valves to stop operating, leaving some valves open and some closed. The crankshaft continues to rotate slamming pistons into valves, and possibly ruining block, crank, rods, cylinder head, and valve train. Almost no reusable parts in this case, a complete engine swap could be required, surprised you were able to drive it home.
Old 12-06-2006, 07:47 PM
Dodge5.9's Avatar
Hey look at the bright side you will get to build a motor how you want it now. Thats pretty cool until you think of the cost. Hope all goes alright. No one like to see pictures like that. Good luck.
Old 12-07-2006, 04:05 AM
putzer's Avatar
I am with infidel on this one. also check all the bolts that are under the timing gear cover. I have seen oil pump bolts come out and do the same damage as the dowel pin falling out.
Old 12-07-2006, 08:05 AM
gmctd's Avatar
Yeah, except that he drove it home, and only one valve - the exhaust valve in that cylinder - was damaged.
Looks more like piston to broken valve to cylinder head juncture broke the cam gear, probably precipitated by valve float.
Stock valve spring tension is low to ensure long life for the cam lobes with the flat-tappet lifters - they look like an upside-down nail - used in low-rpm engines.
Stock valve spring tension is designed to hold just above stock governor spring limits - good idea to limit rpms to less than 2700 with stock valve springs at over 100kmi on engine, imo.
Old 12-07-2006, 08:15 AM
LanceD's Avatar
hopefully you can figure out what caused it so we can learn from it
Old 12-07-2006, 08:48 AM
b.lee's Avatar
man i gotta do my KDP ASAP.
Quick Reply: destroyed 12 valve pics
