Delivery valves
the higher the number the more fuel they flow. i have never heard of 201 delivery valves. the 191's flow the most and if you want more than that there are laser cut delivery valves. are you misreading the "210" pump? it would be a 210 pump if its a 97 or 98 manual but the 210 is a reference to the injectors not the delivery valves both add fuel but are 2 completely different things. hope this helps.
The 201 are marked on top of them ,the engine is rated 130 hp ,I also have a Marine P7100 pump and it has 181 DV ,the marine 4bt are 250hp?
I have talked to many poeple and no one has any info on them ,this engine was a test engine.
Scott
Scott
