Dana 80 SRW Drum to Disc swap...
I currently have an 80 out of a 2nd gen 3500. I am wishing it was the disc brake version. Theoretically, the base housing should be the same, so i should be able to remove the drums and backing plate, and bolt up axle flange caliper mounts from a disc brake truck. But that doesn't mean its true. My goal is to convert my assembly, then upgrade it.
Other forums and google have not been much help, has anyone done this or know anything? Thank you!
Couple links with OE style disc swaps using the updated flange...
fordmann.com | F-250: Dana 70U Rear Disc Conversion
Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 1-ton fat ***
Bradleysram
01-08-2010 10:49 PM
