Dana 80 ID
Dana 80 ID
I believe I know the answer but I wanted to be sure. Looking under the hood of the truck in my sig the axle code is DRL and the desription is REAR AXLE DANA 80 (HYB
I see no mention of limited slip so I assume it is not. when I first got the truck it spun both tires backing up on gravel and i thought it was LS. but since then it seems to get stuck really easy in 2wd so it either is not or is worn out.
So...should it say limited slip under the hood if it has one?
thanks, pacmule
thanks, pacmule
Yeah the underhood label would say it if it has it....
I think the production line code is: DSA Anti Spin differential.
You can always jack up the rear end and manually spin one tire, see if the other tire spins the same direction (limited slip), if it spins the opposite direction it's open diff.
