current rating for block heater?
Old Jan 14, 2005 | 06:17 PM
Rattlerattle's Avatar
Howdy,
What is the draw rating for the block heater? I want to bomb the plug. The new plug that I have is rated at 15 amps. Will that be ok or do I need a higher rated plug?
Thanks
Old Jan 14, 2005 | 06:20 PM
infidel's Avatar
The heater is about 6 amps, 700 watts.
Old Jan 14, 2005 | 06:26 PM
DieselDaze's Avatar
Its a good idea to plug into a heavy duty timer so your meter does not spin all night.
Rich
Old Jan 14, 2005 | 06:41 PM
Thanks for the speedy replys.
Old Jan 14, 2005 | 10:20 PM
Fueling around's Avatar
Actually an inexpensive appliance timer will work just fine if you follow one simple rule. Do not use the off control. It will kill the contacts. Use it to start the block heater. You stop it by unplugging which saves the contacts. I've use the same timer for close to 10 years.
A 15 amp circuit will normally handle two comparable block heaters.
Old Jan 14, 2005 | 10:31 PM
got...DIESEL?'s Avatar
kimstart (who makes our heaters)also makes a t-stat add-on that will series onto the element via unplugging in the existing 110 vac wires from the element and plugging it in place, then screwing a heat transfer snap switch into another available water source which also is part of the supplied harness.
Use them all of the time on smaller standby generators.
rjm022
Dec 11, 2019 09:17 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
Reelay
Dec 1, 2005 06:14 PM
hotdram
18
Nov 5, 2004 06:16 AM
