Cracking Purolator Fuel Filter
Old Sep 17, 2007 | 09:43 PM
metazz's Avatar
Question Cracking Purolator Fuel Filter
Just had the second one in 2000 miles and was just wandering if any one has had any trouble ? The crack is in the top where the square rubber ring go. There is 4 spot welds there and the crack starts in the spot weld and goes out to the edge of the filter housing and leaks a lot of fuel. Or does any one have the E-mail address of purolator.
Old Sep 18, 2007 | 12:56 AM
Crimedog's Avatar
I don't know an email address for Purolator, but I can say I've run a couple of them without issue. You could try doing a search, I have read here that a bad overflow valve can allow too much pressure to build up and crack the filter housings.
Old Sep 18, 2007 | 09:44 AM
infidel's Avatar
Filter cracking is a common result of excess fuel pressure.
You didn't happen to stretch your overflow valve spring?
Old Sep 18, 2007 | 09:36 PM
metazz's Avatar
no and the fuel pressure is at low end of spec. 25 psi at idle
Old Sep 19, 2007 | 08:01 AM
jl4477's Avatar
I have had trouble with the purolator fuel filter as well in the past few months. i switched to fleetguard, and havent had any trouble yet.
Old Sep 19, 2007 | 09:45 PM
dodgeman01's Avatar
Yeah I have cracked 2 of them on my truck. I now run a fleetguard with no problems. I also run 75 PSI of fuel pressure.
DM01
triton20x
Jan 30, 2010 10:48 AM
twhman
16
May 8, 2007 10:59 PM
bc3
Jul 21, 2006 09:33 PM
rws
Jan 4, 2005 08:16 PM
Superduty12v
Oct 28, 2002 11:19 PM
