coolant temp fluctuation
Old May 5, 2011 | 11:32 AM
scjfly's Avatar
http://www.youtube.com/watch?v=pb9IX5QPmog
Hey guys, here is a video of my coolant temp gauge fluctuating. It does it under all conditions, city driving, freeway, etc.
I asked a diesel mechanic at a International Mx Facility who happens to have the same truck, and he said that it shouldn't fluctuate.
I asked a mechanic at the dodge dealership and he said the fluctuation is normal.
I read on Geno's that there is a replacement thermostat that should help with this?
Question is, is this normal or should I change out my thermostat? And if so, should I go with the standard Cummins thermostat or the new one?
Thanks for helping.
Clark
Old May 5, 2011 | 03:23 PM
cj360trider's Avatar
mine fluctuates as well a t stat from cummins will prolly take care of it if it bothers you. as long as you arent getn hot and you dont mind watching the temp gauge move around alot itll be fine. the cummins t stat is built much better than most aftermarkets
Old May 5, 2011 | 04:05 PM
patdaly's Avatar
Bet it is an aftermarket T-stat. I don't have a Cummins place close, I replaced mine with the premium Napa brand and it works much better, still fluctuates, but not nearly as fast or as far as yours does.
Old May 5, 2011 | 09:16 PM
Robert Rausch's Avatar
Mine has been fluctuating for 287,000 miles. I think it's normal.
Old May 6, 2011 | 11:05 AM
infidel's Avatar
Totally normal, read your owner's manual.
Mine have been doing it for over half a million miles.
I would start worrying if they didn't do it.
You really only have two choices, load the truck up like it was designed to be used or get used to it.
Attempts to fix it with a different thermostat usually result in the engine running even cooler.
In 1998 after getting tired of people complaining Cummins electronically changed the coolant temp gauge into basically an idiot light.
Personally I'd rather have a gauge that tells the truth.
Old May 6, 2011 | 04:53 PM
I like it that way. When I'm pulling a load I can tell just how hot the water in the radiator is by how low the temp gauge goes when the t-stat opens and the engine takes a drink of coolant. If the radiator water is really warmed up, the temp gauge only dips a little bit--if the radiator water is relatively cool, the temp gauge dips a lot.
Old May 7, 2011 | 10:11 AM
scjfly's Avatar
Thanks guys for all the info! I guess i'll sit tight and not worry about it, but I'll replace it with the cummins part when I do a coolant flush.
This forum is great!
hawkeye759
25
Mar 10, 2009 09:18 AM
ingramg
Feb 8, 2009 07:26 PM
coalburner400
Apr 11, 2008 09:16 AM
1stdodge
Jul 4, 2006 10:34 AM
heavyboostin
Mar 10, 2005 09:36 AM
