control arm cam bolts?
Old Mar 12, 2006 | 08:40 PM
Rattlerattle's Avatar
Unhappy control arm cam bolts?
I was installing my lift with new control arms. Had a heck of a time removing the old arms. I guess after 11 + year’s things are good and seized on. I had to cut one of the top bolts, which was fine I was able to get replacement grade 8 bolts.
The cam bolts would not come out even with liberal amounts of spray and heat. So they got cut out.
Are they a dealer only bolt? Is the correct term camber or caster bolts? Do the eccentric washers come with the bolts?
Thanks
Old Mar 12, 2006 | 11:57 PM
halerazor's Avatar
i beleive they are a dealer only part i think they are like 15-20 dollars each. they do come with the washers
Old Mar 13, 2006 | 03:43 PM
TRCM's Avatar
the nut, bolt and washer are seperate.
I spent like 30 bucks for all of it for both side of the lower arms.
megajoltman
Nov 1, 2009 01:58 AM
itr.#1446
Apr 5, 2008 06:24 PM
feets
Jul 31, 2007 07:24 AM
PWT05Dodge
May 26, 2006 06:45 PM
