Compression Numbers
Compression Numbers
What should compression be in a 12 valve? Got mine up and running after who knows how long and it's bad! Gonna check timing first but this thing won't start on it's own. Needs some spray to get it going. Once it does it's nothing but white smoke. So before I start putting money into this thing I'd like to be certain I have a solid motor first.
I just tested my 300K mile 96 12 valve and got 400-410 on all but one cylinder. I was told that 375-425 is acceptable but that consistency between cylinders is more important.
White smoke is usually a sign of slipped/retarded timing. Or a puked head gasket letting water in. Injector tips will show something other than soot if water is making its way into a cylinder.
Low fuel delivery system pressure will also cause white smoke.
http://www.cumminsforum.com/forum/94...-12-valve.html
http://dodgeram.info/tsb/1996/14-07-96.htm
kyle_truck_pull
Nov 4, 2009 11:06 AM
sCreamin400
Nov 2, 2008 01:46 PM
Racing41
Mar 12, 2008 10:48 PM
