Cold starts and location of Idle Adj.
Old Dec 24, 2004 | 07:32 PM
condensr's Avatar
Hey all,
Just bought a 96 2500, and seek some advice regarding cold starts.
When I started it from cold this morning, (35F outside) it let out a large cloud of white smoke, and it required some throttle feathering to keep running, for about 20-30 seconds. Might this be something up with the high idle, or a misadjusted idle speed? I dont have a diesel tach, but the dash tach indicated ~500 rpm when cold and in park, no AC on.
On that topic, if it does need the idle speed adjusted, where's the locknut and screw? The haynes manual I have shows a picture, but for the life of me I can't find it on the injector pump. Any hints here?
Thanks!
Shane
Old Dec 24, 2004 | 09:09 PM
kd460's Avatar
Her ya go:
http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Might want to set the idle a little highr for winter (I do about 1000), then back it down to 750 for summer.
Check out this website, it has alot of great info on it:
http://dodgeram.org/support_pgs/diesel_ix.htm
Hope this helps, Kevin
Old Dec 27, 2004 | 09:06 AM
RBFD415's Avatar
Condensr:
You can be sure that adjusting the idle speed will make all the difference in the world for cold winter starts!
But why does tha Haynes book sucks SO BAD? I noticed the same thing when I tried to use it for idle speed adjustment the first time.
Also- why does the idle speed keep sliping/dropping and need so much adjustment??
Old Dec 27, 2004 | 09:41 AM
infidel's Avatar
It's metal to metal contact, the vibration of a diesel engine hammers the contact points, screw gets peened shorter.
Old Dec 27, 2004 | 09:55 PM
dieselhawg's Avatar
Try adjusting the idle,that should really help.If the overflow valve has not been changed,that would be worth a shot,really helped my cold running.
Old Dec 28, 2004 | 03:48 PM
ride_a_hd's Avatar
I agree. New overflow valve made quite a bit of difference in my cold-wx starting and running.
Old Dec 29, 2004 | 02:47 AM
condensr's Avatar
Finally found it and adjusted. I don't have to keep on the throttle anymore to keep it running cold. The URLs above helped.
I'm still interested though in adding an actuator so I can flip a switch in the cab and get ~1000 rpms for the warm up. I know others have used AC actuators from old GM carbs for this, anyone have any advice on where/how to mount up?
Oh, and I found today that my rig does indeed have a block heater! Looks like it has never been plugged in to. Good to know about if the temps really get low around here. (rare!)
97catintenn
Jan 7, 2010 11:33 PM
AkTallPaul
42
Feb 5, 2007 01:28 PM
59FORD
Apr 7, 2006 12:28 AM
12valve
Dec 29, 2005 11:40 AM
mr T
Sep 11, 2005 10:51 AM
