checking timing
Old Jul 9, 2005 | 12:14 AM
marv h.'s Avatar
checking timing
Is there a way to check the timing without going through the whole timing process? I had a powerstroke outrun me yesterday, so I think mabee there is something a little out of adjustment. Also, how much does a 4" exaust help the performance of the 12 valves? Thanks for any replies.
Old Jul 9, 2005 | 03:23 AM
got...DIESEL?'s Avatar
wat's out of adjustment is the fuel Crack that AFC and bump the plate forward a few thou. You'll be all smiles. Jus make sure to mark the plate before you move it so the baseline setting is retained. You've got the gauges, now play around a little with the parts that you have stock. You'd be surprised at the power gains you can get just by bumping this and squeezing that. You have the 913 pump...a good place to start. And yes, free-er flowing exhaust helps tremendously!!
Due to the exacting tolerances ....10th's of a millimeter per 1/2* of timing, I am not absolutely sure, but I have to believe a dial indicator is the only way to know exactly where you are at....let alone make any adjustments accurately.
Old Jul 9, 2005 | 10:06 AM
infidel's Avatar
You don't have to go though the whole process to just check the timing but as said before you have to use a dial indicator. Just find TDC and measure the mm of rise at the #1 delivery valve and you'll know the timing.
The other method is to use a diesel timing light. With a light you just have to find TDC then apply timing tape that is calibrated to the diameter of your dampener to the dampener. Then you can check timing just like a gasser. It won't help you much with a light if you want to change the timing though.
Old Jul 9, 2005 | 01:01 PM
marv h.'s Avatar
Thanks for the replies guys. I need to figure out how to get into the AFC to start tunning.How do you get those screws out, and will there be parts and springs flying out when I get it off??
Also, where can I find a diesel timing light?
Old Jul 9, 2005 | 02:02 PM
dezlsmkr's Avatar
It would probably be cheaper to take it somewhere and have them time it for you. I think that diesel timing stuff is kinda high and not really worth it if your not going to be timing alot. There will be nothing fly out when you take of the AFC it is no big deal. There really isn't anything under there besides that plate that is screwed to the pump. And a little arm the hangs out the bottom of the AFC. If yours has never been messed with i think one of the screws will have a round head that you will have to try to take a chisel or something to make a slot or to turn it out of there. Then replace it with a regular screw. The only way to know is to try you shouldn't hurt anything just do some reading up and take your time. And DONT DROP ANYTHING IN THE PUMP.
Old Jul 10, 2005 | 01:53 AM
marv h.'s Avatar
OK I will try that. Thanks!
cluckmaster
Jan 29, 2007 04:13 PM
kingofdodge7131
May 2, 2003 05:23 AM
kingofdodge7131
Apr 30, 2003 11:02 PM
deezel
Jan 19, 2003 07:51 AM
dalton4
Nov 25, 2002 04:02 PM
