check valve in tranmission cooler line
What does the check valve do in the transmission cooler lines on a 95 3500? This is the rubber hose that connects to the cooler on the passenger side of the motor.Can you replace the rubber hose and leave out the check valve?
Pretty sure it is to prevent torque converter drain back to the pan. I have been meaning to change mine, new trans oils in park but haven't had time to yet. DTT makes a replacement line.
Some people remove the ball because they feel it causes a restriction and could stick closed overheating the tranny.
I have no idea if this is based on fact or fear.
My rig didn't come with the ball, dealer added it for free when the truck was only a year or so old. It did make a big difference in how soon you could move after being parked for a long time.
When I upgraded to a Suncoast I had them remove it, I don't mind waiting 30 seconds to move.
It's based on fear. The valve is an anti-drain back as said- it keeps the TC from draining back to the pan when you park. DON'T DRILL it. Remember, stock 47RE doesn't pump fluid in park- needs to be in a gear or neutral to pump.
Never heard of one actually sticking closed and blocking the line- tho I have had one not seal and still allow drain back.
Check valve
SMOKNISB
24
Oct 23, 2006 09:12 AM
