cheap 370's
Old Feb 25, 2008 | 01:02 PM
primal13's Avatar
cheap 370's
hi ya'll i'm looking for a cheap single 370 marine. i don't know what i did but my #1 is going or is bad. thanks
Old Feb 25, 2008 | 01:36 PM
stock600's Avatar
Try Chuck, at new era.
Old Feb 25, 2008 | 06:13 PM
dieselman2300's Avatar
This is the cheapest I have found them.
http://www.citydiesel.net/injectors-...cPath=22_26_49
Stock600, New Eras injectors are NOT marine injectors they have the correct spray pattern. Unless Chuck started carrying Bosch Marine 370s.
Old Feb 26, 2008 | 12:18 PM
primal13's Avatar
thank ya for the info i got one on the way
Old Feb 26, 2008 | 05:25 PM
stock600's Avatar
How do you like your 370's? Is this the injector that is a true marine inj. and has slightly the wrong spray pattern, does it effect power any or just smoke a little more? Boy the price is right where dieselman2300 said to look. Looks like only 50 bucks or so a piece, not bad good luck.
Old Feb 26, 2008 | 07:03 PM
stock600,
The ones I posted from city diesel are Bosch Marine 370s. They DO NOT have the correct spray pattern, but that hasnt stopped MANY people from running them.
I ran the Bosch Marine 370s in my truck for about a year (25,000 miles), I then switched to New Eras 370s with the correct pattern. I can say that the New Eras were less smokey, the idle haze was less, and the EGTs were down about 100*-150* at wot.
I now run DDP4s, these are a GREAT injector. They are 50hp MORE than a 370 and they have less smoke around town the EGTs are down around 200* at WOT and they have NO idle haze.
Dont get me wrong, the DDP4s will turn day into night when I want to.
I enjoyed the Bosch Marine 370s. They are probably the cheapest, best bang for the buck.
Old Feb 26, 2008 | 07:32 PM
MDMIKE's Avatar
I got my 370's from citydiesel. With the normal 10 plate, 3k gov. springs, timing, filter/exhaust setup, I gained 68 hp at the wheels (with a 180 pump). They haze at idle and smoke pretty good under throttle, but I wouldn't trade them. Egt's aren't much of an issue, even with the stock 35.
Old Feb 26, 2008 | 08:47 PM
Try out a set of DDPs injectors, then come and tell me you wouldnt trade them.
DDPs injectors are night and day difference from the 370s.
Dont get me wrong, I liked my 370s alot.
I now LOVE my DDPS.
Best part about the DDPS is there is NO idle haze, and the EGTS went down compared to the 370s.
BTW the DDP4s that I have are a 140hp injector.
Old Feb 26, 2008 | 11:44 PM
stock600's Avatar
Do injectors and plates act any diff. in a 180 vers 215 pump? And do you know any one thats run the New Era 435's with good luck? Thanks
Old Feb 27, 2008 | 02:08 AM
Dieselnick's Avatar
The 215 pump will give you much more power with the same plate/injectors. Check out the fuel plate chart at pdrdiesel.com.
Nick
Old Feb 27, 2008 | 09:03 AM
TxDiesel007's Avatar
AS stated here
370s are an awesome bang for the buck, but once u go to a higher end injector, well, they seem inferior. I ran 370s, and took em to 450 rwhp with a set of twins, Although they have the incorrect spray pattern, as stated they are fun, and were hazy at idle. I did hate that, and i did hate that they had surging to them as well, turned out to be my throttle return springs on the pump tho. Id do them again if all i wanted was 400 rwhp, no joke...
I run a set of dragonflys now, pretty awesome set and the feeling is comparable to swapping your stockers to 370s, when u go up from 370s to flys. They are alot of injector, and do haze slightly at idle, then again my truck is overfueled a bit and needs tuning lol...
But its apples to oranges when running 370s to a high end injector...
Rick
Old Feb 27, 2008 | 10:04 AM
stock600's Avatar
kind of hate to hear theres that much diff. from the 180 to 215 pump. I been waiting for an engine for a month tring to get a 96-98, well i got a 97 comming from ebay but on the id tag it says 3-16-97 for date and 180 for hp i quess that means it was in an auto truck? But still when i replace the del. valves and zero plate her it still less than a 215? I was hoping maybe they were the same except maybe delevery valves so something to make the 35hp differance? Any help on this or help understanding the diff. in the 2 pumps, i mean they are from the same year and all... I can see maybe more of a diff. from the 160hp pump from 94-95......Thanks Ryan
Old Feb 27, 2008 | 02:01 PM
Dieselnick's Avatar
I wouldn't worry. By the time you get finished modding the 180 pump for racing there will be little if any difference between it and a 215.
Nick
Old Feb 27, 2008 | 06:19 PM
primal13's Avatar
like every say's they are hazy at idle, and my egts are higher. but there is something about sitting at a light when one of theses blender with a header pulls up beside you and revs it a little, then you leave him in a cloud and watch him choking in the rearview.
Old Feb 27, 2008 | 08:21 PM
krazykarl454's Avatar
hey guys i see some people runnig 370s on VE-pump engines. do you know what i'd have to do to run them? is it just as simple as lowering the popping presure of the injector? i have access to a poppet tester. also does anyboddy know how they compare to POD's?
thanks -karl
