changing rear ratio??
Thinking about changing rear end ratio from 4:10 to 3:73 or 3:54....on my 97 dually auto....just use it to haul my 3500 # slide in camper....trying to get rpms down closer to sweet spot. right now running 2250 at about 70mph. don't want to change tires... which gear set do you think would do the job best?? are the 3:54's to high? anybody want to swap? What says u?
My 98 5 speed had 4.10s. It was horrible. I priced switching to 3.54's, but with the 410's stock you need a new carrier for the D80 like mentioned earlier. Which is very spendy. I luckily found someone who wanted to trade axles, worked out well. 3.54's are definitely the way to go with the 5 speed.
