brand of tps suggestions?
Old Jun 11, 2011 | 08:09 AM
corn binder's Avatar
i belive the tps may be getting worn, my tq keeps locking/unlocking in third gear between accel/decel. any suggestions would be great.
Old Jun 11, 2011 | 08:43 AM
blackimpala's Avatar
You could try one of these to save some money.
https://www.dieseltruckresource.com/....html?t=142641
http://www.dnrcustoms.com/zen2/index...products_id=97
Floyd
Old Jun 11, 2011 | 09:49 AM
nickg's Avatar
pull codes first, apps 99.99% shows a code. if you need one search for Timbo, his apps is more durable, simple to instal and a fraction of the cost compared to anyone else.
timbo's is 160$ delivered,
with your symptoms I doubt its an apps issue, sounds more line a t/c lock up issue which is typically a dirty ground or alt leaking ac voltage
Old Jun 13, 2011 | 09:40 AM
infidel's Avatar
My experience has been the TPSs from Napa last much longer than the dealers.
Much cheaper too.
Old Jun 13, 2011 | 09:32 PM
oldblues's Avatar
hi
how about drill and flush it ?
i did mine 2+years ago and it still works perfect!
tried one from napa first and it barely made it 6 mounths???
Old Jun 15, 2011 | 09:38 PM
greasy's Avatar
I drilled mine, flushed with electric motor cleaner then put a screw in the drilled hole
I've had to remove the screw once for another round of flushing out, drilled it so a straw would fit.
Old Jul 17, 2011 | 06:29 AM
where are you guys drilling at on the tps?maybe i'll drill the old one and clean it out and put it back on to see if that works. i bought a napa tps it was $200 so far so good, it has a 1 year warranty too. i didn't buy one from advance/auto zone because their electrical components are junk. the same day i replaced my tps, i replaced the ignition switch lifetime from advance. bye monday i had to have it warrantied already. junk!!!
whosdunit
May 17, 2014 08:54 AM
Opus
Mar 14, 2011 01:12 PM
jlipskoc
Oct 6, 2009 05:29 AM
littlebuddie
17
Feb 27, 2009 10:08 AM
midwestdually
Mar 21, 2003 09:06 AM
