Brake rotors, 95 4wd
Old Apr 3, 2013 | 10:57 PM
glockrow's Avatar
was a very frustrating day! I spent the entire afternoon trying to remove the right front hub so that I can replace the brake rotor. The hub is stuck solid, I've tried everything I could find in these forums to no avail. Is there any reason that I shouldn't go rent a big puller? Could I break something? Does anyone have any suggestions?
Old Apr 4, 2013 | 06:51 AM
For some reason this was posted in the 1st gen forum, vs the second gen. I don't know if the setups are different, but on my first gen, the rotor and hub are pressed together with the lug studs.
Not the same on the 2nd gen ? the search criteria came up with a ton of info. on how to do the front brakes on your truck, if you specify where you want the information from in the search function.
https://www.dieseltruckresource.com/...archid=5416766
This thread below, in particular, gives you "pictures" to view and tells you the hub must be removed to do it properly.... although I've never done one on a 2nd gen myself
https://www.dieseltruckresource.com/...or+replacement
I would suggest spending the $50 and buying yourself a repair manual.... or at minimum the cheapo chilton or hayes manual available just about anywhere ...
Old Apr 5, 2013 | 08:29 AM
Mopar1973's Avatar
In a perfect world, you do not have to remove the hub to remove the rotor. The rotor should pound off of the hub. I just got doing them on a 2nd gen. To remove the hubs without breaking a sweat, heres what you do: There are 4 14mm bolts holding the hub in place that thread in through the back. They should be 14mm.Take them all out, and thread two of them back in at opposite corners. Get a 16MM 12 point socket (so it fits over the head of the bolt but not past the built in washer and you don't ruin a good socket/head of the bolt) and an extension long enough that it will contact the spindle (best to have 2 people, 1 to turn the wheel the other to center the extension on the spindle and monitor the hub) and with the truck running (DO NOT HIT THE BRAKES) turn the wheel and force the hub out 1/2 inch at a time ALTERNATING between bolts so you don't **** the hub inside the spindle/housing. This is how I did it on a friends 2nd gen and at 176k miles my 3rd gen is due for hubs tonight.
Old Apr 5, 2013 | 11:29 AM
infidel's Avatar
Use your truck's built in hydraulic press> http://www.cumminsforum.com/forum/94...ake-rotor.html
Old Apr 5, 2013 | 09:47 PM
joem's Avatar
the 95 does not have slip off rotors, hub must come off
rbertalotto
Aug 27, 2011 11:56 AM
96_12V
Apr 25, 2008 05:41 PM
04ctd
Aug 3, 2007 04:19 AM
genesis
May 24, 2007 07:43 PM
1320
May 6, 2003 06:30 PM
