Brake issues...
Old Aug 1, 2011 | 01:53 PM
4merhockeypro21's Avatar
Brake issues...
Looking for some help...I have a major issue in regards to my brakes. I have a 1996 2500 4x4. I'm having problems in getting my front brakes to release. The master cylinder and calipers/pads have been replaced. Numerous lines have been replaced as well. If you drive the truck you can feel that they don't release. Let the truck sit for a while and they are fine again, though they never feel right when depressing the pedal. Gets worse the higher the outside temp. Help?
Old Aug 1, 2011 | 04:55 PM
patdaly's Avatar
Did you replace all of the rubber hoses on the front?
Old Aug 1, 2011 | 05:01 PM
I have not replaced any of the front lines. I will also add that I don't get much fluid out of the lines when they are off either. New lines would be a quick and easy fix.
Old Aug 2, 2011 | 07:24 AM
esde's Avatar
Sounds like your rubber lines have collapsed inside. It restricts the flow of fluid returning to the master cylinder. A quick fix, just did mine at $30 each.
Old Aug 2, 2011 | 07:36 AM
Excellent! Will give that a try, and thanks for the help!
Old Aug 2, 2011 | 07:43 AM
patdaly's Avatar
Yep, I got all 3 from Rock Auto, at that time they had even Raybestos hoses cheap.
schoust
Dec 10, 2006 06:57 AM
Earthmover627
Nov 21, 2006 05:50 PM
Twogun
Oct 29, 2006 08:44 AM
rednose
Jan 17, 2006 05:07 AM
partytyme
Oct 7, 2005 08:58 PM
