Boot Leaks..........
Old Feb 26, 2005 | 04:56 PM
Ricktye's Avatar
Anyone use soapy water on the turbo boots to check for leaks? What kind of rpm would one need to get some airflow/pressure into the system to check 'em?
TIA
R...
Old Feb 26, 2005 | 06:01 PM
infidel's Avatar
You won't get enough boost unless the truck is under load i.e. driving or dyno.
If you have an air compressor you can make an adaptor with a 4" hose clamp type rubber drain pipe coupler. Connect one end to the turbo inlet and in the other a short piece of 4" pipe capped with a 1/4'' port drilled and tapped into in for the air supply.
Old Feb 26, 2005 | 07:27 PM
SmokinFive9 4x4's Avatar
Where's the best place to get replacements? Found a good sized gash my IC outlet tonight. Time to replace them anyways.
Old Feb 26, 2005 | 08:14 PM
Fueling around's Avatar
PDR
http://www.piersdiesel.com/DodgeBoots.htm
Old Feb 26, 2005 | 08:46 PM
Can you get them just black? Don't like the blue,,,ew.
Old Feb 26, 2005 | 09:56 PM
First you want a source, then you get picky on the color. Just kidding!
Not sure what Piers offers as alternative colors.
I see silicone hose in blue, black, & red
Old Feb 26, 2005 | 10:26 PM
LOL my truck is black orange and red, not sure adding another color would help it look any better lol. Actually, I've decided to repaint it, all white this time, but I still want the engine bay to be not so multi colored :-) I'll have to give them a call.
Old Feb 27, 2005 | 10:33 PM
spunbearing's Avatar
The black hoses aren't as good as the blue ones. The black are neoprene/rubber and the blue are silicone. I still have the black ones but when they go I'll switch to the silicone.
abchoppers
Jan 26, 2011 05:38 AM
95black2615
Oct 8, 2008 03:34 PM
243
Jun 2, 2004 11:30 PM
WTTD
May 28, 2003 08:03 AM
csaverline
Oct 23, 2002 04:55 PM
