Boost
Old Jan 9, 2009 | 01:09 PM
13FOX's Avatar
TICK........TICK.........TICK...........
No offense.
Old Jan 9, 2009 | 11:03 PM
greg@Lockitup's Avatar
What's the old addage? "It's not a matter of if you can get away with it" "but a matter of how long you can get away with it"
Old Jan 10, 2009 | 08:11 AM
high bid's Avatar
Question:
I can't seem to get this boost figured out. Current mods in sig + adj boost elbow screwed all the way in, which should block the waste gate from opening, correct? But according to my gauge, the boost hardly ever reaches 20psi. Is there something wrong here as I would like to max boost out @ 35psi by adj the elbow. Or is it that only when towing or under load, I may see max 35psi?thanks.
Old Jan 10, 2009 | 10:06 AM
infidel's Avatar
high bid, you need to ask your question in the 24 valve forum for better response.
Old Jan 10, 2009 | 05:02 PM
high bid's Avatar
yea, I guess so....thanks.
Old Jan 12, 2009 | 08:04 PM
b12's Avatar
b12
Hey, I appreciate everyones input on this topic. Correct me if I,m wrong, but if I understand this correctly you have a better chance of blowing the stock head gasket with stock studs if I have the timing advance @ 16* vs the stock timing. Thanks
Old Jan 12, 2009 | 11:16 PM
Yellow Yota's Avatar
Advancing the timing increases the cylinder pressure. So yes.
I think.
Old Jan 12, 2009 | 11:40 PM
DBO63's Avatar
I been running about 50 psi and stock timing on mine for the past two years.My head gasket just called it quits last week. SUCKS
Old Jan 13, 2009 | 10:40 AM
infidel's Avatar
Yes, but 16° is well below the danger zone if you keep your boost under 35psi.
Old Jan 14, 2009 | 12:12 PM
offroad's Avatar
My timing is at 16.5 would you consider boost under 35 to be safe for a stock head gasket there as well?
Running empty with my foot to the floor, I've never seen the boost above 30. I do tow a 10,000lb RV for long distances though if that makes any difference.
Old Jan 14, 2009 | 12:24 PM
97 D-Tec's Avatar
long as your not siting there holding it at over 35 psi while your towing you'll probably be ok.
Old Jan 17, 2009 | 04:19 PM
b12's Avatar
b12
If you do get to 35 pounds of sustained boost w/16* timing, how long would be too long as far as sustaining that amount of boost? Thanks
Old Jan 17, 2009 | 06:00 PM
infidel's Avatar
Till you ran out of fuel
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
