block heater bad?
block heater bad?
im wondering what i should replace the whole heater or just the plug power cord? it was supposed to get down to below thirty the other night so i figured i had better plug'er in i went out the next morning and noticed heater no workie she was cold as ice. what are the chances of replacing just the power cord and it workin or should i just replace the whole thing?
Usually it's just the cord. All that flapping around all year breaks the wires. There are some really cool "Big Rig" plugs that you mount on the bumper. Why not! I think the look like they should be there.
No set temp. It is just on at 750 Watts. You can put it on a timer to come on 2-3 hours before you leave and it will have some bucks on elec. bill. Plug it in when it is below 40F.
Any Cummins shop, big rig store, big truck stop. Check out this thread.
https://www.dieseltruckresource.com/...t=block+heater
Don't go to the dealer. Any Cummins shop in your area carries parts for your engine much cheaper than the dealers.
Block Heater Links
Tons more if you use the search.
https://www.dieseltruckresource.com/...d.php?t=120197
Block Heater Links
Not always true, it pays to check first. It's been several years but last time I replaced a cord the dealer was cheaper by a whopping $8 @ $24.
Usually the problem is in the cord right behind the AC plug. If you want to save some money just replace the male plug. When mine went out I spliced a higher quality extension cord to the middle of the stock cord and ran it over to the driver's side. Saves a few steps plugging and unplugging which is nice when there's two feet of snow.
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
