Bleed pump
Bleed pump
What is the best way to bleed the injection pump?? The complete system from the filter to the tank has been apart and cleaned. Can't get the pump to bleed. Removed the overflow valve and primed the lift pump but no fuel exiting. Thks
Are you getting the squealing/whistling noise that indicates fuel is going through the OFV? How many times did you push the primer button on the lift pump?
The only way I know to bleed after the OFV is to crack the injector line nuts at the injectors and crank the engine until fuel comes out. (Wrap rags around the lines/injectors first, of course)
Bad Ramer Jamer
13
01-12-2008 05:38 AM
jrs_dodge_diesel
12-10-2004 05:14 AM
debolton
24
06-29-2004 09:22 PM
