Best head gasket...
Best head gasket...
Some of you may have seen the thread about my head gasket leaking coolant down the side of the block.. When I take this thing all apart, what should I replace it with? I'm planning on having the head milled and have a valve job done while it's apart. I'm thinking about studding it too, but I didn't realize head studs were almost $500. I do a fair amount of towing, but I've never seen the boost over 36psi, so would a stock gasket work? Are firerings a good idea on a daily driver? I only want to change it once
The Members here are giving you good advice. I also feel that the Cummins Head Gaskets are the best. But FWIW,......I am running 14mm studs and firerings on my 1996 Dodge CTD 12 valve and it is a "daily driver." I have had this set-up in the truck for over four years now with no problems at all.
There are some who say you cannot run firerings in a "daily driver" but IMO, that is just not true. The only negative thing about them is the cost factor.
John_P
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
Conn
Dec 29, 2006 06:30 AM
