Ball joint help!
Old Apr 10, 2016 | 07:18 PM
94ram's Avatar
Ball joint help!
How's it going everyone? I haven't logged on in a long time due to selling my pickup a couple of years ago. I recently purchased a 97 2500 2wd(need to update my sig).
Anyways, I replaced all 4 ball joints about a month ago. Yesterday my passenger side tire looked like the camber was WAY off. I pulled the tire off today and found out the top ball joint was completely out of the a arm but still bolted to the spindle.
The old top ball joints in both sides were tacked welded on. I didn't think I would have to tack weld the new ones on since any ball joint I've done have always been pressed on and a snap ring was in place.
I've read some threads and I'm getting mixed answers. The new ball joints went on pretty difficult, as in the holes in the a arms weren't wallowed out or too big.
Do I need to tack weld them on? Wouldn't that just put all the pressure on the tack welds? Thanks for all and any advice
Old Apr 10, 2016 | 10:16 PM
torquefan's Avatar
Not sure what the issue is, as you mention that the new joints seemed to feel like the interference fit was sufficient as you pressed them in. I know that some replacement joints, such as Moog, have a serrated outer diameter to help hold them in a bore that may have been slightly enlarged by previous joints. Am not sure if the joints you installed had that serrated surface or not, but that's the only thing that comes to mind that you can try. If that's not successful, your only solution may be a new knuckle.
Old Apr 11, 2016 | 09:01 PM
94ram's Avatar
Well I ended up replacing that ball joint and tack welded both uppers. Hopefully that's the fix
Old Apr 12, 2016 | 05:37 PM
ronnie's Avatar
yup, tack weld them. keeps them from working back out.
Old Apr 13, 2016 | 08:43 AM
94ram's Avatar
Alright cool. Thanks!
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
