Bad Crank Sensor?
Old Nov 8, 2009 | 11:46 AM
Big Smoky's Avatar
Bad Crank Sensor?
Can a bad crank position sensor cause no tach, no ac, and no charge? Thats the condition I have no. I checked the plug in front of the #1 valve cover and put dielectric grease on it and it worked yesterday. Went to the truck this morning and now it's messing up again. Sometimes it works fine and then sometimes (most of the time) it doesn't. Thanks
Old Nov 8, 2009 | 12:34 PM
torquefan's Avatar
Yes it can cause that. If the pcm sees 0 RPM it shuts off the ASD relay. Pull that connector apart again and, using a small pick, bend in the walls of the female terminals slightly, so they will grip the pins tighter. Try that for a while, it may be all thats needed.
Old Nov 8, 2009 | 09:17 PM
Dave Miller's Avatar
I had the same symptoms on my 97 and it was a bad crank sensor. Mine was not intermittant it just died. The gap at the damper is 0.050. You might try checking that with a non-magnetic (brass) feeler gauge or a business card. Mine cost about $70 from NAPA.
Yours sounds like a bad connection. Try spraying some electronic contact cleaner into the socket. Also verify connections and ground points.
Old Nov 9, 2009 | 10:22 AM
infidel's Avatar
My bet is more like a broken wire rather than bad sensor.
What probably happened is when you applied the grease just moving around the wire temporary fixed the short.
Probably the broken wire is near the connector.
Dodge0144
Jan 24, 2015 01:43 PM
farmboy99
Jul 24, 2011 07:48 PM
sjester
May 10, 2007 05:03 PM
Gabe32
16
Feb 22, 2007 06:37 PM
sandpuller2004
Mar 30, 2004 09:44 PM
