Axles
Old Oct 31, 2005 | 02:38 PM
Underpsi's Avatar
Axles
What would be stronger a 32 or 35 spline axle?
Old Oct 31, 2005 | 03:04 PM
CTD NUT's Avatar
The 35 spline shaft is stronger as it has a larger diameter of 1.50" compared to the 1.40" (I think - can't remember the exact OD) 32 spline shafts.
Old Nov 1, 2005 | 10:41 AM
Underpsi's Avatar
is there a big difference in strength? should i be worried about snapping axles if i change from a 35 to a 32?
Old Nov 1, 2005 | 11:41 AM
CTD NUT's Avatar
What is the reason for swapping from 35 to 32 spline? There is a notable difference in strength.....while the strength difference is nominal for stock applications, the strength difference could be a factor when playing with a bombed CTD.....of course, how you use and drive the truck is a factor, also! Some of us are much harder on our rigs than others!
Old Nov 1, 2005 | 03:17 PM
Underpsi's Avatar
Well i went to get a posi unit for my truck which is a 35 spline and i went to put it in a found out the hard way that the guy gave me a 32 spline unit. so he wanted to trade my axles for 32 ones and that way it would work ( he didn't have a 35 spline unit). But i took it back and got my money back im going else where with my business the guy was being an about it when i told him i want money in return since im giving my better axles for crappier ones and he got a Pi$$y so i just got my money back but i appreciate the help. Now i just need to try and find a place where i can get another posi unit...... im in ONtario Canada and there doesn't seem to be much here availible so not sure what im gonna do
Old Nov 1, 2005 | 05:19 PM
CTD NUT's Avatar
Maybe I can help with a dealer or something......where in Ontario are you?
Old Nov 3, 2005 | 06:34 PM
ridofpwrstroke's Avatar
if you have the dana 80 and want a selectable locker, IE: arb, go with the dana 70HD with 35 splines. That is what I had to do in my truck. The dana 80 arb wouldnt set up right. It needs a thick ring gear and the aftermarket doesnt have one yet for our truck. You just have to drill your ring gear bolts from 7/16th" to 1/2" I believe. Directly from ARB
Sep 22, 2019 07:27 PM
95black2615
Dec 22, 2007 10:54 PM
bigbrowndog
Sep 2, 2007 08:16 PM
SkyHarborCowboy
15
Sep 9, 2005 11:50 PM
