Axle U-joints
just did mine it was an ugly job,the first time you do it ,think it will be easier now that I know what exactly is involved.Do a search on here to use the power steering to push the bearings out(it's the worst part)and have a 43 mm socket,and lots of never seize for the next time
Break hub nut loose.
Jack up the side of the axle you're working on to drain the fluid to the other side (otherwise you may think your axle seal is leaking later).
Take off the wheel and move the caliper out of the way.
Loose hub nut, but leave it on.
P/S press bearing off (see infidel's picture).
Remove bearing. Support axle shaft.
Remove axle shaft & stub shaft.
Change ujoint & clean shaft.
Lubricate axle shaft.
Slide it in, be careful to not rest it on the seal or get dirt past the seal. The seal is quite a ways into the axle and a majour PITA to replace.
Lube/anti-seize stub shaft, anti-seize where the bearing mounts after cleaning it up.
Reinstall bearing, hub nut, caliper, wheel. Torque everything down.
Other side.
Other side.
kprc51
Jun 14, 2007 06:27 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
