Axle shafts
Axle shafts
Where do yall get new ones when ya break one? I'm havin a hard time finding one anywhere but the dealer and the price is outragous even with a discount. Any east coasters know of a place to get them?
BTW, it's for the dana 70 in my 96
Thanks,
Jeff
Thanks,
Jeff
From: Used to be missoula, montana: Now in Sonoma County California
when you break one you are better off calling up Yukon, supperior axle, Dutchman and ordering a set for your truck.
They make alloy replacements for $300 or $350 for the pair then you are garenteed to have something a little stronger for the next time you hammer on it.
I suggest supperior axle us made quality alloy metals. Yukon is a slightly lower grade and Dutchman i have hear orders thier through supperior then charges a hair more. take a tape and hook it to the inside of the side gear and measure to the flange then call them with the specs. remember to tell them its a full floater and i believe iwh it being D70 it should be 32 spline for you.
i think it is a 35 spline on the 70 and the 70/80 hybrid rear. the 80s have a 37 spline rear. but i would suggest you pull yours out and count it very carfully. and try www.car-parts.com. for used one from thr junk yards. mike
You're right probably, ishouldnt have stated the spline count with such confidence, cause i always say 35spline to people when im preaching about the power lok lsd carrier but for some reason i came across this post here on dtr a few weeks ago i think it listed a 1999 dodge or 2001 but its not the first time ive seen 32 spline listed as the axle spline count
Make DODGE
Model W2500
Number of axle splines: 32 FULL
DANA 70U REAR AXLE - 32 SPLINE
(STANDARD-pinion) REAR
Number of cover bolts: 10
Diameter of ring gear: 10.5"
Number of ring gear bolts: 12
Pinion Shaft Diameter: 1.75"
Pinion Splines : 29
Low Case Ratio : 4.56
Make DODGE
Model W2500
Pinion Splines : 29
mopardude_440
Aug 21, 2012 11:48 PM
bradler
Sep 15, 2009 02:49 PM
joefarmer
Oct 24, 2003 09:11 PM
