asking a question for a friend
Old Nov 16, 2006 | 11:40 AM
kutch's Avatar
Question asking a question for a friend
A friend of mine has a 97 CTD with about 130K miles.
Just recently he has begun to loose oil. He just did an oil change- then took a trip (less than 1000 miles) and used 5 qts of oil. Noticed frothing in the oil...
head gasket?
cracked head?
turbo?
Anything common on this year truck that would signal something?
Thanks
Kutch
Old Nov 16, 2006 | 11:49 AM
TxDiesel007's Avatar
head gasket?
cracked head?
turbo?
Thanks
Kutch
Hate to say but these trucks leak oil
many areas you can start at. The best thing to do tho, is pressure wash the entire engine and run the truck looking for leaks, Common places to check for leaks on these trucks.. Im still battling with my bottom end...
Oil pan gasket and screws (torque to 18 ft lbs, 10 mm socket)
Front timing cover (same specs)
Crank seal behind the balancer, dampener (replaced with TST kit for KDP)
Valve cover gaskets (tightened to 18 ft lbs as well)
O rings for screws for valve cover gaskets
Oil feed line to turbo can get loose on both ends
blowby can cause oil loss as well
Thats all i can think of for now...
Rick
Old Nov 16, 2006 | 11:57 AM
displacedtexan's Avatar
Is it leaking from the timing case? Or anywhere else noticable? My first guess would be the KDP backed out, that would generate a noticable oil leak...
Old Nov 16, 2006 | 11:59 AM
Thanks for helping him out with troubleshooting it Rick, I am feeling lazy about typing tody. But I am working tomorrow! And deer hunting Saturday. My mood is improving
Old Nov 16, 2006 | 03:49 PM
kutch's Avatar
Thanks.
I'm having a few trucks/ guys over this weekend. Going to do some gage installs on this friends 97 TD...Will take a closer look and see if anything stands out....
I guess I'd better get some big sheets of cardboard...I don't want all that oil all over the garage floor!!!!
kutch
Old Nov 16, 2006 | 07:13 PM
infidel's Avatar
Frothing usually indicates overfilled oil getting whipped up by the crank.
Maybe he has the wrong dipstick and is overfilling?
Old Nov 16, 2006 | 07:25 PM
vette95's Avatar
Anybody think about what kind of oil he used? My buddy with a powerstroke decided to change his oil and use Castrol 10w40. He checked his oil about 1 month later and was 8 Qts low! Make sure you use a reputal oil like delo,delvac,or my favorite Rotella.
Old Nov 16, 2006 | 08:00 PM
Got a pair of spikes already
gosh its fun with a lil 22.250 Head shots, clean, no tracking, and easy pickup... glad to hear ur moods improvin, good luck on ur hunt...
Rick
suzukiZrider
Jan 4, 2005 02:56 AM
Intercool
24
Apr 29, 2003 10:45 AM
Hoss
Mar 17, 2003 03:20 PM
