another tcc ?
Old Feb 25, 2009 | 06:47 AM
whitediesel's Avatar
another tcc ?
I am trying to diagnoss a problem in the 97, 47re ,wich at first I thouoght was the trams not going into overdrive. after alot of searching here, I now Know it is the tourque converter not locking up in overdrive. so, I decided to wire a mystery switch to see what would happen. I can now manually lock the converter in third but still nothing in overdrive. is there any possibility it could still be the solenoid or is it definetly clutch slippage?
If it is clutch slippage , Can I just swap the torque converter or do I need to have the tranny rebuilt.
If I can swap the converter, can i put in a performance converter without a performance valve body?
Old Feb 25, 2009 | 06:52 AM
i did install a new speed sensor and a new overdrive solenoid
I did not replace the tps yet
sgT
Aug 1, 2004 11:28 PM
vtailflyer
Apr 2, 2004 10:54 PM
daystar
Feb 19, 2004 06:21 PM
slayerfish
Jan 7, 2003 08:08 PM
RickCJ
Dec 18, 2002 02:23 PM
