Swapping 5spd for 6spd tranny
Old Feb 24, 2009 | 10:32 AM
Bubba J's Avatar
I own a 96 2500 4x4 with a V10. Can you swap a 5spd for a 6spd tranny with out any problems. I have done some research and I believe there shouldn't be any problems but I would like to make sure. That I'm also wondering if any one has done this before. Thanks for any help with this.
Old Feb 24, 2009 | 11:32 AM
halerazor's Avatar
i beleive one is shorter than the other wich means you will need different driveshafts. why the switch?
Old Feb 24, 2009 | 09:07 PM
Bubba J's Avatar
My 5spd lost it's 5th gear and I was think if I was going to replace the tranny why not go with a6spd instead. I think the 6spd is better ?
Old Feb 24, 2009 | 10:15 PM
roughstock's Avatar
You might neeed different cross member, and you will have to move it back. I think a clutch upgrade is needed??
If you google 5 speed or 6 speed conversion, there are a couple of companies that sell kits to do this.
Old Feb 25, 2009 | 08:17 AM
Diesel_Dan's Avatar
When u say you lost 5th gear are you sure that it didnt just fall off the shaft like happens to all of these 5 speeds. Do a search on losing 5th gear.
Old Feb 25, 2009 | 08:33 AM
halerazor's Avatar
the 5 speed is alot tougher tranny, it has alot of aftermarket support. like diesel dan said it probably just fell off.
lovin1stgens
Sep 25, 2012 07:25 AM
starflite3
Jan 19, 2009 06:31 PM
Smooshy
May 25, 2006 11:10 PM
R-O-B
13
Mar 16, 2003 11:59 PM
AFMSgt
Jan 26, 2003 08:27 PM
