ABS & BRAKE lights staying on
ABS & BRAKE lights staying on,And it seems like there is more pedal pressure needed. <br><br> it does have trailer brake on it ??? and it seems there is somethng rattling inside the control box. could that be the problem now. <br><br>It's bad enough i dont have heat!<br>WHAT NEXT????
Re:ABS & BRAKE lights staying on
sounds like you either have a major vacuum leak or your vacuum pump has quit check all your lines for leaks you can also check for vacuum at the pump with the truck running remove the hose and see if you have any vacuum.
BRAKE & ABS lights only come on after 2 minutes of driving.
problem with heat a large seperate issue. the doors ALL work I verified it several times.
I have been back under the dash to verify that everything I took apart is back together.
Is there any type of electrical relay or vacuum check valve that may have gotten disconnected when I had the whole dash apart. ?
Is there a Sure fire way to test vacuum pump. I saw a small 'T' port off one of the larger hoses . can I hook a regular vacuum gauge to that port?? what should it pull at idle?
Oh yeah , I asked what next??
Now the cruise control does not work either. I had to ask!
THEN
someone here at work stole my Haynes manual. Thanx,DAVE
THEN
Everything you mentioned that does not work is controlled by vacuum you can use your gauge it does not mater where you hook your gauge as long as it is a vacuum port I am not for sure how much you should have but I would say somewhere around 10hg.
reaves11
Feb 10, 2013 02:29 PM
polaris800sp
Nov 13, 2008 05:35 PM
mtl0727
Nov 19, 2005 08:14 AM
