98 12V wont turn over
Old Jan 10, 2010 | 04:56 PM
5HRacer's Avatar
Sorry I couldn't bail you out Might do a search in 2nd Gen for neutral safety switch and see if that helps Good Luck
Old Jan 10, 2010 | 05:22 PM
cmac's Avatar
did a search for that all i found is where it plugs into the tranny. gonna go check that and make sure it isnt coroded or unplugged. any ideas on how to test them or how to bypass it?
Old Jan 10, 2010 | 05:59 PM
cmac's Avatar
talked to my uncle who told me how to test it. now i need to find a multimeter...
Old Jan 10, 2010 | 06:07 PM
5HRacer's Avatar
is it 2 wires or 3
Old Jan 10, 2010 | 06:36 PM
cmac's Avatar
its 3 wires just behind where the shift linkage hooks up to the tranny.
Old Jan 10, 2010 | 06:41 PM
5HRacer's Avatar
Road Apples if it was 2 I would say paper clip it but since its 3 thats a more complicated thing What ever happened to Easy
Old Jan 10, 2010 | 07:13 PM
cmac's Avatar
i havent had easy since i had a 79 buick riviera! the neutral saftey switch tested good many times in all gears. continuity in park and neutral and not in reverse drive 2nd and 1st. am i looking at getting a new ignition switch?
update: tested the relays, they are good. i'm not getting any power to the starter relay in the fuse block under the hood. should have power to the 30 cavity at all times. this ought to be fun! or not... so anyone know how to get to the underside of the power distribution box (the fuse block under the hood) where all the wires are?
update2: i used a jumper wire from the battery to the 30 cavity for the starter relay. it worked! it also took care of the ABS and airbaglight. and my windows worked again! anyone know where i can find a wiring diagram for inside the power distribution ceanter? again thanks so much for everyones help!! the problem has been identified, now just need to find the right solution! a jumper wire cannot be a permanant solution, i'm afraid that it will cause more problems down the road.
Old Jan 10, 2010 | 10:32 PM
BigIron70's Avatar
Cummins Guru
Did you check the fuse?
Old Jan 10, 2010 | 10:47 PM
cmac's Avatar
i check all fuses for continuity with a multimeter and they were good. which fuse is no. 2? i'm not getting any power to the number 30 socket for the starter relay in the PDC . i also tested the relay and its good. the wire from the 30 is pink w/ black tracer and runs into JC 2. there are 15 wires that run into JC2 as well as 3-4 other pink w/ black tracer wires so thats where i'm lost. if i run a wire from the battery to the 30 it will start with the key. i would like to fix the problem not just bypass it.
Old Jan 11, 2010 | 10:19 AM
cmac's Avatar
am i reading that wiring diagram correct? the wire running from the fuse to the jc2 is pink w/ black tracer?
Old Jan 11, 2010 | 11:32 AM
Copenhagenjunkie's Avatar
Yes, 14 gauge.
Old Jan 11, 2010 | 02:59 PM
BigIron70's Avatar
Cummins Guru
Fuses can fool you sometimes they will check good but will not carry any current flow. Best to try a new fuse first.
Old Jan 11, 2010 | 03:11 PM
cmac's Avatar
which fuse is it? the diagram says number two but they arent numbered in the PDC, and i cant tell from the label. they all tested good with a multimeter. there are quite a few 30A fuses under there. Thanks
Old Jan 11, 2010 | 03:30 PM
infidel's Avatar
There should be a small brown wire at the starter that triggers the shutdown solenoid relay to lift the the solenoid.
Old Jan 11, 2010 | 04:10 PM
cmac's Avatar
the relay comes up as soon as i turn the key. that was the sound i was hearing, i originally thought it was the starter trying to engage.
