97 Ram 3500 won't start
Old Dec 26, 2012 | 05:07 PM
russ9712v's Avatar
Ok a little back ground info. My truck is a 1997 3500 4x4 diesel automatic and is bone stock. This past weekend my starter got hung up and eventually siezed up causein the engine to shut off, I just replaced the starter this afternoon and a fuse that I assume had blown during the fiasco (10A Engine Fuse), now the engine turns over fine and strong but won't bust off. I am apparently not getting fuel to the injectors I checked the pigtail connector that hooks up to the fuel shutoff solenoid and it is getting no power. My question is could that be my issue? If so where does that wiring start at if this is not my problem then what could it be?
Old Dec 26, 2012 | 05:12 PM
roughstock's Avatar
There is a fuel solinoid relay. it could be bad. it is located on firewall, on drivers side. Some one could help with exaclty which one,
Old Dec 26, 2012 | 05:16 PM
russ9712v's Avatar
I switched out the relay with one that I know is good and still wouldn't start.
Old Dec 26, 2012 | 06:34 PM
infidel's Avatar
Sounds like you didn't hook the small brown wire back up to the starter.
Old Dec 27, 2012 | 08:11 AM
patdaly's Avatar
Or the wires inside broke and the brown insulation is all that is holding it together.......Wire the fuel lever up and see if it starts.
Old Dec 27, 2012 | 10:56 AM
joem's Avatar
when the starter hangs it normally burns up the fuel solinoid itself- as when the starter is on there is more power going to the fuel solinoid for a short ammount of time, sounds like your starter stuck and it burned up the solinoid and thats what shut your truck off
tonycunn
Jun 30, 2013 09:56 AM
redneckhauler
Oct 23, 2010 11:45 AM
Machinos
Mar 16, 2008 01:34 AM
spitzair
Dec 31, 2006 01:26 PM
