97 dually
Old Sep 5, 2005 | 06:09 PM
latemodelracer2's Avatar
97 dually
I just purchased a 97 3500 4x4 diesel dually. The truck had just had the tranny rebuilt it has 180k miles on it. The truck runs great when it is above 10-15 mph it has lots of power from there to when you let out pulling or not. But with a trailer behind it the truck will barely get moving. It has no low end power at all but its fine when it gets to 10-15mph. The truck does have a little black smoke when it idles for a while. But is this the power these trucks have or do i have somthing wrong or am i just use to power since i have a 05 duramax and a 99 powerstroke? ANy thoughts or power tips are welcome since im new to dodge and would like to make this work truck able to work.
I have read about some tq plates, adjusting something called a star wheel and then adjusting somthing else but not sure what to do for my best low end power results. This truck pulls a 20' dump trailer around the farm all day in the grass and it is tough to get it going need that low end oomph
Old Sep 5, 2005 | 10:05 PM
TRCM's Avatar
Something ain't right. Mine pulls fine low and high. I'm not enough of an expert to say what it is for sure, but it may be injector pump timing. I know mine has to have slipped, and it does kill some of the low end when it does.
Old Sep 5, 2005 | 10:48 PM
bmoeller's Avatar
Check the air filter. Get rid of the cat and get a straight thru muffler, or straight pipe it, if it isn't already.
If it is a California truck, the EGR may be part of the problem.
Old Sep 6, 2005 | 09:27 AM
it has a nice set of stainless exhaust on it. A kn drop in filter also. Still not sure what it could be
Old Sep 7, 2005 | 09:38 AM
any tips on adjusting the starwheel or the other thing to get more low end power.
Old Sep 9, 2005 | 05:30 PM
Hayseed's Avatar
Yeah, back it waaaay off and you will develope more power at low end. At that speed the turbo is not up and thus the pump won't give it any fuel.. a no win situation. You have to have fuel to build boost and you have to have boost to get fuel. Anyway back off the star wheel should do it.
Old Sep 9, 2005 | 07:13 PM
ok so how do i do what u describe and where is the starwheel located
Bobcat698
Sep 12, 2006 08:36 AM
Mcmopar
Feb 10, 2006 08:25 PM
CTD NUT
Sep 12, 2005 04:40 PM
RobG
Sep 5, 2003 09:13 AM
patriot pearl blue
Dec 9, 2002 08:53 AM
