96 cummins suburban
Old Mar 1, 2006 | 12:43 PM
cnvrt2cummins's Avatar
96 cummins suburban
Here are some pics of my 96 suburban that I put a cummins in. i really enjoy this truck I hope this is legal. if someone can help me attach pics i will do that instead of the link. http://www.dieselplace.com/forum/gar...do=view&g=1303
Old Mar 1, 2006 | 01:15 PM
DieselDaze's Avatar
copy the full path of the image(s) and paste them into the thread.
If need be, use the icon at the top of the box in which you reply.
Rich
Old Mar 1, 2006 | 05:34 PM
Willy91's Avatar
That is one clean looking setup. Did you have any problems with it fitting or mounting up in the suburban.
Old Mar 1, 2006 | 05:36 PM
TxDiesel007's Avatar
Question
how does that half ton front end like that cummins? How much work to get it to hold up well?
Rick
Old Mar 2, 2006 | 07:13 AM
It is obviously a big job to do everything it takes to make things like "factory". This was my sixth coversion that I have done so I have just a bit of expierence in the process. As far as my half ton chassis it doesnt ever give me any problems. The frame on the chevy is extremely tough because it is basically all boxed in. I just posted pics in my gallery hopefully they will be more visible than the others.
Old Mar 2, 2006 | 07:40 AM
displacedtexan's Avatar
Man that is clean looking on the install!!! Your hard work and attention to detail really shows.
Old Mar 2, 2006 | 04:11 PM
THANK YOU!! I AM REALLY HAPPY WITH IT, I SPENT A DECENT AMOUNT OF TIME MAKING IT LOOK AS GOOD AS POSSIBLE I LIKE BEING ABLE TO MAKE IT LOOK AS FACTORY AS POSSIBLE.
Old Mar 2, 2006 | 04:23 PM
dieselcrazy's Avatar
dang ... that looks awesome. no firewall cutting needed to make it fit ? did u use an auto or 5 spd ? how about some interior pics if it changed anything. and why did you use the 1500 sub instead of a 25 or 3500 suburban. do you do this professionally ?
what kind of $ are you looking at to do the conversion if a fella supplied you with a suburban and and the cummins ? scott
Old Mar 2, 2006 | 04:26 PM
i WOULD BE HAPPY TO SELL YOU MINE EVEN AS MUCH AS I LIKE IT. THE PRICE HOWEVER IS KINDA NASTY WOULD BE INTERESTED IN HEARING WHAT YOU THINK IT IS WORTH AND THEN I WILL TELL YOU WHAT I WOULD TAKE FOR THIS ONE. THERE ARE NO CHANGES ON THE INSIDE OF THE TRUCK. I AM USING A 3000.00 47 RH DODGE TRANS, GOERAND BROS TRANSMISSION SHOP IN IOWA. LIFETIME WARR.ON CONVERTER 100K ON TRANS.
Greguw
Cummins Conversions
Oct 31, 2010 10:54 PM
masterphreak
Mar 29, 2007 07:03 PM
ridofpwrstroke
Apr 28, 2006 04:06 PM
cnvrt2cummins
Jan 6, 2006 09:49 AM
