95 cummins auto tranny shifting constantly
Old Oct 12, 2011 | 04:08 PM
daledlathrop's Avatar
I have read many posts on this subject, but still am not sure if they address my exact problem. I bought the 95 Ram 2500 Cummins new, and from almost the beginning it displays the following problem: After finally shifting into overdrive, it will not stay there for more than a few seconds at a steady speed. It will shift partially out of overdrive (RPMs go up by 200) then immediately back down 200. 4 seconds later it shifts partially out, up 200 RPM, and back. It does this constantly. If I take overdrive off, it still does the same thing, shifting partially out of 3rd and back in. Is the unshielded alternator ground wire the problem? The computer? Should I buy a shielded ground wire and route it somewhere away from the main alternator wire bundle? Can one even buy a shielded ground cable?
Old Oct 13, 2011 | 07:24 AM
CarlJensen's Avatar
On the 95, like mine, it's usually the TPS doing that to you. Do a search on TPS here. More info than you need. Or just replace it with a potentiometer.
Old Oct 13, 2011 | 08:14 AM
Thanks - I'll look into TPS solutions and reply with results.
Old Oct 13, 2011 | 09:50 AM
infidel's Avatar
Read> http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Old Oct 13, 2011 | 10:10 AM
Thanks - I am definitely getting steered toward TPS as the problem.
Arlon
Dec 29, 2005 09:21 AM
RED99CTD
17
Dec 7, 2005 09:59 AM
Lil Dog
Jan 17, 2005 05:34 PM
04ctd
Nov 26, 2004 01:08 PM
