95 12V Check Engine Light
Hi folks, today my check engine light came on and the alternator quit charging. I've seen other threads where the PCM went bad and an external regulator was installed. I have checked the 2 small wires going to the alternator and don't have voltage to either one, is this a classic case of PCM failure?
If the Tach is intermittent, then I would be checking the Engine Speed Sensor as another did just in another thread. IF the PCM senses a erratic pulse from the ESS it will shut down the other circuits it controls.
Tested Alt by unhooking harness except large batt. wire, grounding one small terminal and hooking the other to batt +. Old alt. didn't change voltage at all, tested new one when installed and it put out almost 25VDC
Oh, by the way, I now have a working charging system and cold A/C, all of this with a dead tach
Sorry to hear, there wasn't any mention of the AC system.
I've repaired the alternator with a set of brushes, pretty cheap.. Also they do start to stick and can be cleaned. I just did that last fall to the new alternator I got a couple years ago.
What circuits are controlled by the PCM? The "other" thread mentioned the alternator and air conditioning, well my A/C has never failed to blow cold air whether the tach is working or not.
I figure it is most likely the sensor, the tach bounces at anything under 1K RPMs when it is working
As long as everything else is working I really don't care if the tach works or not
Been running this way for probably the last 100K miles.
If you have a check engine light on it will set codes.
Check them with the method described here> http://dodgeram.org/tech/dsl/trouble..._DTC_codes.htm
Bad thing about living out in the country and being self employed, you really never know how long that trip to town will actually take
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
